Starter Woe's....
Nearing the completion of a massive overhaul as I bring my track beast back closer to stock. All has been going very well until I got to the starter.
The old was original, 22 years old. Preemptively I decided to replace it while everything else was apart. AC Delco Gold part number 88864474.
I installed it, wired with the purple lead on the small post, then the battery cable, grey and brown wires on the larger brass post. Reinstalled the headers, plugs, dipstick and the coil packs and plug wires. Torqued everything, and attempted to start. Didn't happen. I had power, and the solenoid did it's job, but it did it over and over and over... Multiple "clicks" in short succession.
From what little I know and have been able to research, this is an indication of not enough power getting from the battery to the starter OR a bad starter from AC Delco. So, I pulled everything apart... again. I took the starter to two different auto parts places to check that the starter itself wasn't bad, and they both checked it as OKAY. I watched the second test, and it worked perfectly. Next step, replace the battery to starter cable. Got that done. Then, for good measure, I really cleaned each of the cable ends before installing them yet again. Hours later, I had everything back together again (less some blood, lots of sweat and lots of fiberglass shards from the wrapped headers...). Moment of truth.... click click click click, but no turnover.
It seems that the grey and brown wires are taking power off of the post that they share with the battery cable, so I don't know how they might be the problem. I do get the clicking when I turn the key so it seems that the ignition relay is functioning. What else is there?
I'm in need of your help. Where do I turn now?
Thank you in advance.
Jeff
Yes, I understand the purpose of the ground is to allow the circuit to be complete. Without it, the power from the positive side of the battery wouldn't move, and the starter won't engage. The power needs to "flow" through the starter and back to the battey.
On the DMM (mine is older with a needle rather than a digital readout), am I looking for DC current?
I won't be able to get back to it today, but I will tomorrow.
I appreciate your help.
Best, Jeff
I just saw your edit - Excellent idea! That's what I'll try first (jumper to block)
Best, Jeff
That is a fast “bypass” test if the battery negative block ground is bad.
I will perform the tests that you indicated and post them here.
Again, my humble thanks and appreciation for your time and expertise!
Jeff
Just to follow up and close out this thread; i checked for voltage drop on both sides of the starter, positive and negative. The values were all really low and well within limits. I checked grounding points on the frame and the engine, all good. I decided to try starting the car. Click click click click... I then tried to jump the Vett with my F-150... It started right up! What????????
Several days ago (before I started this thread) I had taken the battery to Auto Zone to check it. I wasn't really to sure how much the sales person knew about cars (football - especially the Pats, Yes, cars???), but I assumed that he could at the very least accurately check a battery. Turns out I was wrong... So, having watched many videos I decided that I should check the voltage on my battery (which I had not done as I *** U MEd that the Auto Zone clerk knew what he was doing!). Guess what, 11.3 volts! According to one of the videos I watched, you have to have at least 11.6 to get the solenoid to close the circuit. Lesson learned... I bought a new battery and the car sprung to life and I learned about voltage drop and how to test for it!
So, the car is up and running and feeling good!
I know that you have helped a lot of folks here on the Forums, and I'd like to express my sincere appreciation for your ideas and support not just for me, but for everyone that you've helped. Thank you. I wish I lived closer to you - I'm sure that I could learn a massive amount from you and in return we would have some good laughs and maybe a few cold ones...
Jeff
Parasitic drain shows a .15mA. The limit is 0.05, correct? I checked each of the fuses under the hood, all good. I would have had to wake up the car and then trick close the pax door and wait for sleep mode to get at the fuses in the forward pax footwell. Have to go to work tomorrow so I disconnected the negative side of the batt and left the trickle charger on.
Couldn't do the voltage drop on the alternator - my cheap Harbor Freight DMM burned up
My fault... What DMM would you recommend (without going over the top).
Here's mine Rob,
USAF: T-37A, T-38, C-21, KC-10
AAL
C-10-30, B757/767, A300/310, MD-80, A319/320/321Flexjet: EMB-545 (it tried to kill me and the everyone on the jet! POS!)
Private firm: G-280, G-5 (G-450 and G-550)
Turning wrenches on my 03 retired from track duty, Z06
If I end up your way for an overnight, I'll buy you dinner!
Thanks for the recommendation. I'm going to order it now.
Jeff
Here's mine Rob,
AAL
Jeff
Nice !!…so you were a “Gucci Boy” !!…if you ever fly into RSW let me know !!
