Help appreciated!
Old Aug 27, 2025 | 11:44 PM
Stormymoore's Avatar
Stormymoore
Cruising
Default Help appreciated!
Hi, I recently purchased a C5 Corvette and had been driving it for a couple weeks when one night I stopped and got gas and when I started it back up, I noticed a loud tick took it home and parked it
im assuming it’s atleast a cam and lifter job now but I’m just curious what could’ve caused it ?
I got the valve covers off and noticed that two lifters on the driver side didn’t seem to be lubricating
Old Aug 27, 2025 | 11:51 PM
Stormymoore
Cruising
Default New to here sorry.
Didn’t really know how to get the video uploaded here so I uploaded it to YouTube
Old Aug 27, 2025 | 11:55 PM
Ltngdrvr's Avatar
Ltngdrvr
That sounds like a big honking exhaust leak, not a lifter knock.
Does this car have headers on it?
Old Aug 27, 2025 | 11:57 PM
Stormymoore
Cruising
again sorry if I’m not doing this right
but car is completely stock. And I manually tested oil pressure and it’s sitting at 40psi at idle
it also seems to be rpm related. As it gets worse with rpm
Old Aug 27, 2025 | 11:59 PM
Ltngdrvr's Avatar
Ltngdrvr
Still sounds like a bad exhaust leak.
Old Aug 28, 2025 | 12:00 AM
Stormymoore
Cruising
thank you very much for the advice. Really looking for all I can get!
I’ve had someone look at it and they said lifter but that was just us listening to it run for a few moments.
it gets more repetitive with higher rpm
Old Aug 28, 2025 | 03:09 PM
helga203's Avatar
helga203
do not start again until you pull those valve covers off. Thats not a exh leak. If it is then ill shut up.
Old Aug 30, 2025 | 11:15 AM
T-RAY1978's Avatar
T-RAY1978
I agree from the video definitely sounds mechanical
Old Aug 30, 2025 | 11:17 AM
Stormymoore
Cruising
Pulled covers and it seems 2 lifters aren’t lubricating so I’m assuming it’s a oil pick up or oil pump issue caused multiple lifters to fail
Old Aug 30, 2025 | 12:12 PM
helga203's Avatar
helga203
If you didn't know what oil psi you had i would change out oil pump while its torn again its a big job. Not expensive if you do the work, if not, hope you have deep pockets.
Old Aug 30, 2025 | 12:24 PM
killain's Avatar
killain
Oldtimer
I have to agree with T-Ray and helga, If you have pulled the 2 valve cover and start the engine, you should be able to put a clean shop towel over what ever rockers , and see if the tapping slows down or stops. If so shut it off and see about changing both the oil pressure switch and or the oil pump, but is odd that if it was the oil pump, why it only started once it was shut off for a few minutes for a fuel up. But I would want to check the oil pressure while running. The old adage is 10 PSI for every 1000 RPM's, so if the engine is idling at 700 RPM
and you have 10 PSI then your good.
Old Aug 30, 2025 | 01:00 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
broken valve spring ???
Old Sep 3, 2025 | 09:03 AM
Moved to C5 Tech.
Old Sep 3, 2025 | 09:51 AM
lucky131969's Avatar
lucky131969
The OP has 40 psi at idle confirmed with a mechanical gauge. The OPS or oil pump does not work in this equation.
Old Sep 3, 2025 | 09:52 AM
lucky131969
As already mentioned, check for a broken valve spring. A mechanics stethoscope will help isolate before pulling the cover.
Old Sep 3, 2025 | 12:26 PM
Stormymoore
Cruising
Very much appreciate the reply’s. I’ll definitely pull the covers next to see what’s wrong, I’m just hoping my cam isn’t absolutely garbage.
To Help appreciated!
