IPC removal
Old Sep 5, 2025 | 05:27 PM
cdw's Avatar
cdw
Default IPC removal
i've had a few post on here about my DIC buttons not working and how I was going to solve this. I was out riding around this afternoon and stopped in to see my friend who has a truck and auto repair business. they had a 2002 c5 in for a turn signal problem. they knew I was going to remove my IPC in a few weeks and asked if I wanted to watch them remove the one in the shop. I said hell yes. 20 minutes and they had it out. did not remove the center console or dash or pillar. I'm not intimidated by this project any more. I was very lucky to be in the right place at the right time.
Old Sep 6, 2025 | 08:53 AM
bookyoh's Avatar
bookyoh
Looking forward to your updates as I contemplate the job to get to my DIC buttons, and a possible evaporator core replacement.
Old Sep 6, 2025 | 11:59 AM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
Care to describe just how this is done without removing any of the items you mentioned?
Old Sep 6, 2025 | 03:35 PM
cdw's Avatar
cdw
they did the underneath unbolts and the trunk and emergency and inside ac air temp sensor covers and had to pull back the part of the console cover that covers the ignition key and the temp sensor very carefully without breaking it. drop the steering column, with the screws removed from the upper panel lift it up slightly and pull out by tilting to the right a little and down with the right side and up with the left. hope I described this ok and if you need more of a description let me know while it's still fresh in my mind. btw the lower knee cover had the temp sensor still attached to it if that helps. they just unplugged it from behind. that c5 had the HUD and mine does not so that's just one more wire harness I don't have to mess with. those two guys are very good with the c5 corvettes for being as young as they are.
Old Sep 6, 2025 | 10:14 PM
bookyoh's Avatar
bookyoh
Are they located in the Columbus area? That may be a better option to have them replace my DIC buttons.
Old Sep 6, 2025 | 11:30 PM
Good thing you have found an easier way to do the job. Good luck when you do yours.
Old Sep 7, 2025 | 07:33 AM
redzg's Avatar
redzg
Very few DIC issues have been reported as corrected by replacing the DIC buttons. Not saying there hasn’t been some, but some diagnostics should be involved — which, unfortunately, as far as I can tell require removal of the IPC.
Old Sep 7, 2025 | 08:37 AM
grinder11's Avatar
grinder11
Very interesting thread. My DIC buttons all work, but the top 3 sometimes don't, and sometimes do, illuminate at night! Most often, they do not. All bulbs were checked and were OK. Go figure.
Old Sep 7, 2025 | 09:19 AM
cdw's Avatar
cdw
I agree a 100%. I have read everything I can and the DIC buttons replacement did not solve the problem.
Old Sep 7, 2025 | 09:20 AM
cdw's Avatar
cdw
Carroll Ohio 43112.
To IPC removal
