VATS bypass question
Old Sep 14, 2025 | 04:25 AM
rnoggle's Avatar
rnoggle
Default VATS bypass question
I'm having an issue with the security light coming on whenever I hit a bump in the road. Most likely due to a loose fitting key causing the chip to loose contact in the ignition cylinder.
I've watched several videos and read online comments about the bypass and they mostly seem to remove the knee bolster and follow the wire from the ignition cylinder down to the connector and cut it there and solder in the proper resistor.
My question is, can I just cut that wire all the way up near the cylinder itself? My key bezel is missing and the wire is hanging right there, exposed. Seems like I should be able to cut it there rather than pulling the center console and knee bolster. And if I leave the wires there, tucked behind the bolster, I can always reconnect them if the bypass doesn't work for some reason.
Thanks for any assistance!!
Old Sep 14, 2025 | 07:29 AM
Moved to C5 Tech.
Old Sep 14, 2025 | 12:29 PM
lucky131969's Avatar
lucky131969
I disagree. The ignition lock cylinder only reads the key resistance upon insertion and key turned to the ON position. When you are driving the BCM is not looking at the key resistance value. There is a separte contact in the ignition switch itself (NOT LOCK CYLINDER) that senses the key inserted into the ignition. This contact may be failing, or associate wiring.
Old Sep 14, 2025 | 08:06 PM
rnoggle's Avatar
rnoggle
Ok, Thank you for that info!!! I was just getting ready to pull the console out!!
So, if that contact or associated wiring were failing, that would cause the Security light to come on whenever I hit a decent bump?
Old Sep 15, 2025 | 02:02 AM
oelarse's Avatar
oelarse
Check for historic DTC codes .
You have probably poor connection at the ignition key resistor/sliprings .
As far as I know , if the BCM has with reading problems the keyresistor it will prevent the TDR relay to activate and will you have no start condition.
But while you driving with an armed UTD(universal Theft Deterent system) should not be dissarmed by a DTC like B2721/B2723(Pass key circiut problems)
Old Sep 15, 2025 | 08:47 AM
lucky131969
Except the OP is not reporting a "no crank" condition, and the BCM only reads the resistance on startup.
Old Sep 15, 2025 | 07:07 PM
rnoggle's Avatar
rnoggle
Yeah, I've never had a "no crank" issue.
Just the security light when I hit a bump.
I just thought it was due to the key being very loose in the ignition. I mistakenly thought it was reading the keychip all the time.
Thanks for the info guys!!!
Old Sep 16, 2025 | 04:58 AM
oelarse's Avatar
oelarse
I noticed you had no starting issues .
My statement is your corrrect , the BCM monitor the passkey voltage all the time as you as thought .
I made this test on my car today and made this video proving this fact.
I started may car with no codes and it was idling all the time during the 3-4 min test, disconnected the passkey resistor , got the B2723 due to passkey voltage jumped from 1.56 volt to 4.97volt and
back to 1.56v when I reconnected the resistor . Cleared the code but the Securitylight did not went out before I shutdown and started the car again
Old Sep 16, 2025 | 06:54 AM
lucky131969
My statement is your corrrect , the BCM monitor the passkey voltage all the time as you as you thought .
This video show these it
Thanks for doing that.. it certainly corrects my understanding
@rnoggle are you certain you have no codes?
Old Sep 16, 2025 | 05:12 PM
rnoggle's Avatar
rnoggle
Thank you so much for doing that!
I haven't checked to see if there is a code. Guess I should do that next.
Old Oct 3, 2025 | 08:25 PM
rnoggle's Avatar
rnoggle
I finally got around to doing the bypass this week.
I have to cross a really rough RR crossing going to work and the security light would come on every tiime.
Since I did the bypass, I haven't had the light come on at all.
To VATS bypass question
