Wheel size help
Old Sep 16, 2025 | 06:40 PM
SattarC5's Avatar
SattarC5
Default Wheel size help
Would 18x11 and 18x13 +36.25 wheels fit on a c5 corvette? If so how would they fit.
Old Sep 16, 2025 | 10:25 PM
USAZR1's Avatar
USAZR1
They would fit like crap, with lots of poke.
Old Sep 16, 2025 | 11:55 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Sep 19, 2025 | 01:31 PM
grinder11's Avatar
grinder11
You'd need a mini tub setup, along with the proper offset/backpacking, to avoid the poke. If you're going to run a 13" wide rear wheel, how wide of a tire are you planning on running??? 345's? Which are 13.58" wide! In keeping with a stock look, years ago I bought re-pop thinspokes in 18"×10.5" for the rear from Bob@House of wheels. I run 315-30-18 Michelin PS2s, which are 12.4" wide. They fit almost perfectly inside the wheel well. No rubbing ever. Just a super tiny bit of poke. I have about 1/2"-5/8" clearance to the inner fenderwell on one side, and 5/8"-11/16" on the other. So, are you doing this for aesthetics, for racing, or both?
To Wheel size help
