Misfire / Bog under load
Old Sep 27, 2025 | 11:07 AM
c5lapped's Avatar
c5lapped
6th Gear
Default Misfire / Bog under load
Let me give some info about the car first…it’s a manual ‘99 with 160k. It has an idle surge when it’s cold, it’ll surge between 750-1200rpm (rough estimate). When it’s warm it doesn’t surge. Recently it started bogging / missing when under load, specifically WOT (wide open throttle). Check engine light is on only for long tubes (o2). Once it bogs / misses for a few seconds it will stop and continue to rev all the way up and keep pulling but there’s a good amount of time where it’s bogging. Does anyone have experience with this issue? I uploaded a short video for reference.
Old Sep 27, 2025 | 01:39 PM
killain's Avatar
killain
Oldtimer
If you want to see any DTC here is how to do that :
Old Sep 27, 2025 | 02:15 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Unfortunately many things can cause this so if you don’t have a factory level scan tool to see if there are any misfires and able to interpret live data seek out a diagnostic shop in your area…not a “grease monkey” repair shop or a dealership…they only know how to change parts…a video is of no use to diagnose this.
Old Sep 28, 2025 | 11:09 AM
1999corvettels1's Avatar
1999corvettels1
I’m just guessing, maybe it needs a fuel filter, or fuel pump is getting weak?
Time to get a fuel pressure tester, and see if it’s in range.
Looks like 58 psi.
Old Sep 28, 2025 | 06:48 PM
Moved to C5 Tech.
To Misfire / Bog under load
