TPMS Location
Old Oct 7, 2025 | 12:15 PM
henk in veld's Avatar
henk in veld
5th Gear
Default TPMS Location
I want to replace the TPMS on my 2002 Z06 but i can not find it in the trunk behind the driver seat and befor i turn the car inside out i hope i find the awnser here.
Old Oct 7, 2025 | 07:17 PM
KOZ's Avatar
KOZ
TPMS are in the tires.....
Old Oct 7, 2025 | 07:22 PM
lucky131969's Avatar
lucky131969
I feel like this is a trick question, because a Z06 does not use tire pressure sensors.......unless that functionality has been added/enabled.
Old Oct 8, 2025 | 08:09 AM
grinder11's Avatar
grinder11
Must be a bot!!
Old Oct 9, 2025 | 11:08 AM
henk in veld
5th Gear
Let me refrease my question looking for the TPMS VOB reciever and it is not in the trujnk behind the driver seat.
It was further then expected i found it.
Next to the gas intake.
Thank you for youre help.
Last edited by henk in veld; Oct 10, 2025 at 09:07 AM. Reason: It was helpful and the problem is fixed
Old Oct 9, 2025 | 11:14 AM
helga203's Avatar
helga203
iIs this what your talking about??
https://www.tirerack.com/accessories...able-mx-sensor
Old Oct 9, 2025 | 11:29 AM
whbrennan's Avatar
whbrennan
https://www.corvetteforum.com/forums...01-04-wow.html
Old Oct 9, 2025 | 11:34 AM
henk in veld
5th Gear
2001 - 2004 C5 Corvette Key Fob / Low Tire Pressure Monitoring System Receiver Module  LTPMS OEM 10312535
This part its location.
Old Oct 9, 2025 | 11:59 AM
lucky131969
https://www.ebay.com/itm/31708527545...U_jGaftI9RkS4c
Old Oct 9, 2025 | 12:00 PM
Dads2kconvertible's Avatar
Dads2kconvertible
GM thinks it is in the trunk behind the driver's seat.
Do you maybe have an export spec car? Maybe those were in a different spot?
Old Oct 9, 2025 | 12:44 PM
henk in veld
5th Gear
Thank you but this is a later model aperantly the 2002 Z06 model its placed some where else because nothing is there.
Old Oct 9, 2025 | 12:49 PM
henk in veld
5th Gear
The car is from California USA.
Thank you for the help my quest will continu.
Old Oct 9, 2025 | 01:00 PM
lucky131969
Take a picture of the area you are looking. The location did not change for 2002. Do you have working factory key FOBs?
Old Oct 10, 2025 | 08:10 PM
SilverC54me's Avatar
SilverC54me
The RFA module for the keyless entry and tire pressure monitors is located on the driver side in the trunk area just aft of the rear speaker. It is under a bump out in the close out trim.
For an 01 to 04 Z06 the TPMS feature can be enabled with a Tech2 since all 01+ cars used the same RFA module. For the Z06 this was turned off.
Now are you looking to add the TPMS sensors to the wheels? If so you just need to enable the feature in the RFA module and add the correct sensors to the car.
Gary
Old Oct 11, 2025 | 02:52 AM
jdmvette's Avatar
jdmvette
Night Owl for life
^yup its all in there
To TPMS Location
