Dumb question on seat track fix
Old Oct 11, 2025 | 09:19 PM
Tommy Bahama Fan's Avatar
Tommy Bahama Fan
Default Dumb question on seat track fix
So I replaced the shims on the passenger side seat. No problem.
Got it all back together. No problem, no more rocking.
Set the seat in to test and well...
When I push the switch forward the seat goes backwards.
When I push it backwards the seat goes forward.
Now I've never really used the passenger seat so its either that way from the factory or I swapped sides with the threaded rods (I probably did this).
Any one able to check the passenger side seat movement please?
Old Oct 11, 2025 | 09:55 PM
Raith's Avatar
Raith
I would guess more likely than not the wiring is backwards, you can invert the wiring and reverse the polarity of the switch. Ive had to do this before when one side of a switch lost continuity and would. Ove in one direction.
Old Oct 11, 2025 | 10:14 PM
Erikf555's Avatar
Erikf555
My car does the same thing after I replaced the shims. I’m 87% sure that I got the threaded rods mixed up, but was dreading digging back in so much that I bought a set of C7 seats. I’m such a baby sometimes….
Old Oct 11, 2025 | 10:32 PM
Tommy Bahama Fan
Whelp....
I had them swapped....
All better now.
Thanks all.
Old Oct 11, 2025 | 10:42 PM
Erikf555's Avatar
Erikf555
Old Oct 11, 2025 | 10:58 PM
hyperv6's Avatar
hyperv6
YEs there is a right and left and get them mixed up you will need to swap them.
Old Oct 11, 2025 | 11:19 PM
Tommy Bahama Fan
Yep, funny thing is I knew that. I took pains to make sure I didn't mix them up even.
Oh well, 30 minutes later I had them switched back.
I've done dumber things.
Old Oct 12, 2025 | 12:33 AM
Moved to C5 Tech.
Old Oct 12, 2025 | 09:58 AM
redzg's Avatar
redzg
And I always figured I was the only one to do. My solution was easier…
To Dumb question on seat track fix
