Tpms
Old Oct 27, 2025 | 05:05 AM
saintjean's Avatar
saintjean
Default Tpms
Hello,
I'm french and I've got a C5 convertble 1998.
Do you know where I can buy TPMS for this CAR ?
Is it possible to change the batterie inside the part ?
Thank you for your help.
Old Oct 27, 2025 | 08:00 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I would suggest 'Rock Auto Parts' for the sensors, and no, unfortunately, the batteries are not replaceable.
Old Oct 27, 2025 | 08:27 AM
lucky131969's Avatar
lucky131969
Originally Posted by saintjean
Hello,
Is your C5 a European version or U.S. version?
Old Oct 27, 2025 | 10:50 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Yes, the batteries are replaceable.
https://www.corvetteforum.com/forums...batteries.html
https://www.corvetteforum.com/forums...-tutorial.html
If you can find new sensors that is probably a better option.
Old Oct 27, 2025 | 12:08 PM
oelarse's Avatar
oelarse
Here is some videos on batteryreplacement part 1 , 2 and 3
Old Oct 29, 2025 | 05:24 AM
saintjean's Avatar
saintjean
It's a US version. It came from Florida !
Old Oct 29, 2025 | 05:51 AM
saintjean's Avatar
saintjean
Thank you for the informatuons !
You can find TPMS on Amazon for 46$ : A-Premium 4PCS Pre-Programmed TPMS Sensor Tire Pressure Monitoring Sensor - Compatible with Chevrolet Corvette 1997 1998 1999 2000-315MHz - Replace 10438853
Do you try it ? What do you think about it ?
Old Oct 29, 2025 | 09:11 AM
lucky131969
I would not order from Amazon, but that is your choice.
Here is where I purchased mine from:
https://www.rockauto.com/en/moreinfo...pt=12036&jsn=1
You will need a trigger tool ...they will not work with a magnet.
Old Oct 29, 2025 | 10:39 AM
saintjean's Avatar
saintjean
OK thank you, I'll go en Rockauto for my TPMS
Old Oct 30, 2025 | 12:24 PM
leadfoot4's Avatar
leadfoot4
Good plan!
After watching the videos, it seems to be a lot of tedious work, with some risks, when brand new replacements are easily available.
Old Nov 3, 2025 | 10:44 PM
RicardC5's Avatar
RicardC5
Purchased on Amazon a set of sensors and a trigger. Worked fine.
TPMS sensor TPMS sensor
Relearn Relearn
To Tpms
