Why is a wire attached to the ignition switch bezel ??
Old Nov 1, 2025 | 05:37 PM
phoneman91's Avatar
phoneman91
Default Why is a wire attached to the ignition switch bezel ??
Why is a wire attached to the ignition switch bezel? What is the purpose of this wire?
Old Nov 1, 2025 | 06:55 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
THere isn't a wire attached there!
Old Nov 1, 2025 | 06:59 PM
capeokw56's Avatar
capeokw56
There is on my 04' and I wondered what it was for too.
Old Nov 1, 2025 | 07:01 PM
redzg's Avatar
redzg
Yes there is. It doesn’t connect electrically to the bezel, but it does loop around and have an eyelet attachment. The wire, orange I believe in my ‘99, is part of the security — the key resistance as I recall.
Old Nov 1, 2025 | 10:10 PM
Moved to C5 Tech.
Old Nov 2, 2025 | 09:07 AM
helga203's Avatar
helga203
the key resistance there's one black and a black white wire for that only if your year changed.
that was mine anyways on my 99. iicr
Old Nov 2, 2025 | 10:37 AM
mmartinez's Avatar
mmartinez
The Ignition switch cylinder has a set of contacts that press against the keys resistor pellet, this is part of the pass key security system. There are two small gauge wires that leave the Ignition cylinder and have a connector that connects them to the BCM.
Old Nov 2, 2025 | 10:49 AM
lucky131969's Avatar
lucky131969
Yes...there is( or there was orignally). Technically it's a cable, containing a black and white wire for the lock cylinder. It is attached to the bezel with a clamp to manage the length.
To Why is a wire attached to the ignition switch bezel ??
