ECU Issues
Old Nov 2, 2025 | 08:13 AM
NOLA70's Avatar
NOLA70
Default ECU Issues
I've had the car for almost 5 years now, and after finally installing Speed Engineering LT heads and catless X-pipe, which sound amazing) I knew I would finally have to spring for a tune. I brought the car to Mitch @ Tuned By Norm in Houma only to find out he can't tune it...for now.
My 2003 Zo6 has a cammed LS3 in it, and it seems the previous owner (builder) was having the same issues. The issue is the ECU is not reading the o2 sensors. So, he turned them off. Yeap (not a mistype), all four O2 sensors were turned off in the ECU.
The car's been running fine, other than loading up at idle. Above idle, it seems to work just fine.
Let's assume the O2 sensors I installed when I installed the headers are fine. I believe all it can be is either the harness, which I will check for continuity, or the ECU itself.
I've already found a diagram for the ECU plug and have identified the 2 upstream O2sensor positions on the plug.
My question is, if there's continuity in the wires, then how to I test the ECU? What value at the ECU should I be getting? for the upstream O2 sensors?
Old Nov 2, 2025 | 08:24 AM
helga203's Avatar
helga203
just check your readings at the ECU plug
millions of post on how to check 02 sensors. 2 easy test. AI will have all ur answers. Just need DMV
Old Nov 2, 2025 | 11:41 AM
lucky131969's Avatar
lucky131969
You will most likely get better search results searching for "PCM" instead of ECU.
Old Nov 2, 2025 | 12:25 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
With a scan tool and with the O2 heater circuit fuse removed (fuse 15) you should see 450mv’s (O2 sensor bias voltage) key ON…if seeing 450 the wiring is fine…checking the O2 signal circuit is best tested with a LOW impedance DMM…whoever turned off all 4 O2 sensors is an idiot !!…he should NOT be tuning cars !!
To ECU Issues
