C5 Convert window issue with leaks
Old Nov 11, 2025 | 08:51 PM
professorjim's Avatar
professorjim
Default C5 Convert window issue with leaks
Having ongoing problems with major leaking from drivers and passengers windows in my C5 Convertible. Replaced the top, the full wrap-around windshield gasket, all 6 of the window surround gaskets, and had the alignment and tip-in adjusted to fit correctly. I think it's correct as its dollar bill tight. Still happens. My shop is baffled too. Any ideas would be appreciated. prof jimb
Old Nov 12, 2025 | 10:10 AM
lucky131969's Avatar
lucky131969
If you are saying the seals are "dollar bill tight", then it cannot be leaking from the seals, right? When you are inside the car observing while someone sprays the car, where is the point of ingress?
