BIG Electrical Problem After LED install
I'll keep trying.
I did trace the ground wire to the splice pack 100 at ground point 102. After separating the splice pack from the grounding strap I probed each wire to chassis ground and found only one with continuity to ground. Then test continuity to that wire and the black wire at the switch harness and that was the one. Now I am going to try to find the best way to run a new ground from the harness to the splice pack or from the harness to ground and the lamp socket to ground.
There are too many posts on this forum to mention each that I have reviewed but I want to thank everyone for posting and I also used the Google AI which in many cases pointed me to posts on the forum. I will contnue to test for the draw tobe absolutely sure.
First the draw was there all the time. While the fuse was good in the 10 amp circuit of my multimeter the fuse holder was loose. I did install new ground wire from the fog lamp switch and the fog lamp sockets to chassis ground. Have not fully tested that yet, still waiting for the switch to arrive and don't want to take a chance of jumping the switch for a number of reasons, not the lease of which is next.
I did a parasitic draw test again, this time pulling each and every fuse, relay, etc in number order in both fuse boxes. The only significant drop in draw (.40 amps) occurred when pulling fuse 25 (BCM - Ignition 1, Insrtrument Panel Control) and returned when it was reinstalled. There was a smaller drop (.15 amps) when fuse 31 (Power feed door right) was pulled but that stayed down when every other fuse was pulled and reinstalled.
This certainly looks like a BCM issue caused by the LED fog light install which burnt out the switch and caused the car to totally shut down. Didn't restart until the next morning. I 'm going to be looking for BCM diagnostic help and/or resetting procedures.
At this point, I am totally without power in the car. No lights, no starting, no messeges - nothing. Battery tests great with the negative terminal disconnected but after installing the negative terminal the voltage drops to about 7.5 volts.
