failing ignition switch?, not VATS?
Note: key comes out without turning fully counter-clockwise
I already installed LMC5 and the brown wire, do I need to do the C5 Corvette VATS Security System Bypass , or is it failing ignition switch, not VATS.?Thanks, Doug
What happens when you open the door
what happens when the key is inserted
what happens when the key is turned to the ON position
what happens when the key is turned to the START position
What has been replaced? What happened prior to the car not starting?
Gary
Gary
1 - nothing
2 - nothing
3 - nothing
4 - nothing
I try to crank it 5 times, and on the 5th time putting the key in it clicks (seems like it recognizes the key then), and then it starts.
I drove it to a different location in hopes it would be ok, and it started fine after that,
Then going to the 3rd location I turned it off, did my errand and then it wouldn't start,
it try to crank it this time it took about 10 times , almost gave up, thinking I had to have it towed, and it started! over a course of about 5-10 minutes waiting, removing the key, and putting it back in.
At this point I have it being looked at, but concerned as they said they wanted to ha
have a locksmith look at it, and I don't think the issue is with the tumblers. and don't
want them dis-assembling the steering column.
appreciate your insights.
I've only replaced the LMC5 column lock, and the brown wire.
I've been concerned that I can remove the key without Turing it completely counter clockwise, the radio will stay on with key removed. (I don't do this on purpose but I'm a little quick on the draw apparently).
1 - nothing
2 - nothing
3 - nothing
4 - nothing
What happens when you open the door? - You replied ...nothing.
So when you open the drivers door:
1) No interior lights illuminate?
2) The Security light does not flash on the IPC?
What happens when the key is inserted? - You replied...nothing
So when you insert the key into the ignition:
1) No fast chime?
What happens when the key is turned to the ON position? - You replied....nothing
When you turn the key to the ON position:
1) No slow chime?
2) Gauges do not sweep and indicator lights do not test?
Gary
https://www.corvetteforum.com/forums...ty-system.html
The dealer wants to replace the entire key and lock cylinder for $1200. that doesn't include the ignition switch, but I'm thinking it is the ignition switch after reading all this,?
Looks likeThe ACDelco D1426D (GM OEM) switch is now discontinued/ unavailable. The correct modern replacement is ACDelco D1499C.
