2002 Lower Oil Pan Bolts
Old Dec 5, 2025 | 11:28 AM
coolbowtie's Avatar
coolbowtie
Default 2002 Lower Oil Pan Bolts
I am wanting to replace the lower oil pan gasket and bolts (Qty.15). I used the GM parts manual to identify the bolt part number and it lists it as part number 11517509 which appears to have been superseded a couple times by 11517591, then by 11588714. I purchased the latest 11588714 but they measure 30mm in length and the original ones I took are measure 35mm. I can't seem to find the correct bolts to match my originals. Any thoughts or suggestions are appreciated.
Old Dec 5, 2025 | 11:37 AM
jcgunn's Avatar
jcgunn
Try ARP
https://arp-bolts.com/
Old Dec 5, 2025 | 11:41 AM
lucky131969's Avatar
lucky131969
Do you have sufficient thread engagement with the 30mm bolts?
Old Dec 5, 2025 | 11:52 AM
coolbowtie's Avatar
coolbowtie
With the 30mm bolts there is only about 1/4 inch or 5mm worth of threads that protrude through the pan, so the extra 5mm seems like it would be necessary. Also the original bolts have sort of a "flared collar" near the hex head which is seems to make them fit better into the bolt holes (see pic)
Old Dec 5, 2025 | 01:03 PM
lucky131969
So you are referencing the through holes on the wings, that there is an extra 5mm protruding.....which does nothing. You should be able to at least estimate the thread engagement into the upper pan, right?
Old Dec 5, 2025 | 01:51 PM
lucky131969
My parts manual only goes up to 2001 for engine parts, but it does show that bolt as 30mm long.
Old Dec 5, 2025 | 03:17 PM
coolbowtie's Avatar
coolbowtie
Correct, so with the 30mm bolts that you referenced, only about 5mm would be engaging into the upper pan, which is 5mm less then the originals (50% less threads). This seems significant to me. There has to be another part number for the correct bolts
Old Dec 5, 2025 | 03:36 PM
lucky131969
Yep. Interesting. Even with the 35mm bolts it's still less that 2 x the diameter.
Old Dec 5, 2025 | 03:49 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
You can obtain them from a fastener supplier such as this: https://www.harfington.com/products/...Ny77rDRW1oJQQM
Old Dec 6, 2025 | 09:02 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
What's wrong with the OE bolts?
Old Feb 18, 2026 | 09:53 AM
VETTEYOG's Avatar
VETTEYOG
2024 C5of the Year Finalist - Unmodified
I was replacing the lower pan gasket on my C5 also, and a bolt broke off. Was going to replace all mine as well, what length did you end up going with?
Old Feb 18, 2026 | 10:44 AM
grinder11's Avatar
grinder11
Try Mid-States bolts, Granger, etc. These aren't highly stressed bolts. Shouldn't need ARP, 10.9, etc. What numbers are on the bolt head?
Old Feb 18, 2026 | 04:01 PM
VETTEYOG's Avatar
VETTEYOG
I know what dia of bolt I need, I was just wondering on the length, and if 35 mm was too long.
Old Feb 18, 2026 | 06:26 PM
helga203's Avatar
helga203
Don't wait for answer he's been off the forums since dec 5
Old Feb 19, 2026 | 09:44 AM
lucky131969
Old Feb 24, 2026 | 11:08 AM
VETTEYOG's Avatar
VETTEYOG
UPDATE... I went with M6x1x35 allen headed bolts and they are the same length as the stock bolts. Could definitely go M6x1x40 and be ok on the length.
To 2002 Lower Oil Pan Bolts
