Harmonic Balancer Wobble - Safe to Drive?
Old Dec 15, 2025 | 10:38 AM
kjb5200's Avatar
kjb5200
6th Gear
Default Harmonic Balancer Wobble - Safe to Drive?
Hello, I have a 2003 C5 with 212k miles. A shop told me the harmonic balancer is bad and I can see it wobbling when the car is running. I wanted to ask if it is safe to drive the car with a wobbly harmonic balancer. The shop told me it is okay to drive just the belt might go bad other than that it should be safe. However, I wanted to confirm with the more knowledgeable people on here. Thank you.
Old Dec 15, 2025 | 10:50 AM
lucky131969's Avatar
lucky131969
Eventually it will walk forward or aft...and leave you stranded. Depending on how soon you catch it in that condition will determine you much more you have to spend for the repairs. Keep your foot out of it...it may last a while. Roll the dice. Get AAA.
Old Dec 15, 2025 | 10:52 AM
mmartinez's Avatar
mmartinez
I would address this problem as soon as possible, when it eventually fails hard, it could cause engine damage, the crank shaft, front engine cover as well.
Old Dec 15, 2025 | 11:01 AM
pnbcoolbreeze's Avatar
pnbcoolbreeze
Yes ... change it. Install an ATI balancer!
Old Dec 15, 2025 | 11:40 AM
jjcoledo3's Avatar
jjcoledo3
2 silver vets
Its safe until its not!!!
Old Dec 15, 2025 | 03:29 PM
sonicss33's Avatar
sonicss33
What are you waiting on? Replace it ASAP before it completely falls apart. The wobble is its warning to you that failure is imminent. 212k is a very good run.
To Harmonic Balancer Wobble - Safe to Drive?
