2003 c5 power drain
Old Dec 18, 2025 | 01:09 PM
DavidDwight123's Avatar
DavidDwight123
Default 2003 c5 power drain
I guys , I’m wonder if it is normal for my c5 battery to be dead 5 days after driving. It’s a new battery and I know a lot of guys use a battery maintainer . Still on an average car with the power off most fuses are not hot . On my c5 the all the fuses stay hot when the car is off .its easy to see why there would be a power drain. Is it normal for the fuses to stay hot when the key is off on a 2003 c5 corvette? Thank you .
Old Dec 18, 2025 | 01:32 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You can’t judge a parasitic drain by if yours fuses are “hot”…if you know how to use a DMM you can watch the video and perform the test…if this is over your head seek out an auto electric shop…unless current is flowing a fuse won’t be hot so don’t go by that and they usually don’t get hot anyway !!
Old Dec 19, 2025 | 03:07 PM
mmartinez's Avatar
mmartinez
I believe the OP is saying that the fuses have power, not that they are thermally hot, my best advice is to perform a parasite current drain measurement before preceeding to more detailed measurements.
To 2003 c5 power drain
