c5 Hard To Shift
Old Dec 27, 2025 | 09:19 PM
Rider.Watts's Avatar
Rider.Watts
4th Gear
Default c5 Hard To Shift
I have a ’99 6-speed with about 130k miles on it. I picked up the car about a year ago, and in that time I have done the clutch, rear main seal, pilot bushing, flywheel, throw-out bearing, slave cylinder, installed a Fidanza short-throw shifter, replaced the transmission fluid, and just flushed the clutch fluid today (it was extremely dirty, and I’ve been daily driving it like that). My issue is that whenever I drive the car, it is very difficult to shift into all gears. Sometimes it shifts into a gear just fine, and sometimes it is extremely difficult. I thought that the bad fluid could have been causing the clutch to not disengage properly, but it didn’t help at all. It is hard to shift with the car on or off, but it is definitely worse when moving. I’m not really sure what else it could be. I’ve seen some people talking about shifter linkage alignment, but I haven’t looked too deeply into it.
Any help or suggestions would be super appreciated.
Old Dec 27, 2025 | 09:31 PM
alex04vette's Avatar
alex04vette
2024 C5 of the Year Finalist - Unmodified
that shifter is terrible in my experience. Ditch it immediately and report back.
Old Dec 28, 2025 | 01:24 AM
Rider.Watts
4th Gear
Any recommendations on which shifter to go with? I hear the c6 shifters are nice but I definitely dont wanna spend 300 bucks on a fancy one.
Old Dec 28, 2025 | 01:58 AM
USAZR1's Avatar
USAZR1
Originally Posted by Rider.Watts
I hear the c6 shifters are nice but I definitely don't wanna spend 300 bucks on a fancy one.
I purchased this mint C6 shifter assembly out of a 2012 Grand Sport, for $75. Deals are out there.
Old Dec 28, 2025 | 10:42 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Are you saying you replaced the clutch slave cylinder and the clutch sometime in the last year and did not flush the clutch fluid at that time?
@TMODcustoms builds and upgrades boxes and shifters. If I were changing I would consider their products.
Old Dec 28, 2025 | 11:30 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
improper shimming of the slave cyl. not getting enough throw ???
Old Dec 28, 2025 | 12:27 PM
Rider.Watts
4th Gear
​​​​​​​yeah lol this was my first manual car and first time doing a job this big. when I went to bleed the new slave I bleed it until fluid came out so it worked fine but I assumed that the brake master cylinder and the slave shared the same reservoir (dumb assumption I know) so I thought the fluid was fine and didn't have any second thoughts.
thank you for the advice ill definitely check them out.
Old Dec 28, 2025 | 12:29 PM
Rider.Watts
4th Gear
my clutch came with a shim and after measuring everything I did end up shimming it
Old Dec 28, 2025 | 01:47 PM
Dads2kconvertible
Given that you're currently having shifting problems I would be bleeding the system again, preferably with a different methodology.
If you installed a remote bleeder the job is much easier.
Old Dec 28, 2025 | 03:10 PM
C5Mat's Avatar
C5Mat
Aside from what everyone else has already mentioned clutch not shimmed correctly and a transmission issue. You can try to do the old "anti venom mod" you just shim the detent spring/plug with some copper washers and it will reduce shifting effort. Without driving your car it's all just a guess.
Old Dec 28, 2025 | 09:32 PM
Moved to C5 Tech for more discussion.
Old Dec 29, 2025 | 12:23 AM
Morritse's Avatar
Morritse
It sounds like he's saying it's difficult to operate the shifting mechanism, which shouldn't depend on anything clutch related, no?
Old Dec 31, 2025 | 01:00 AM
harleydoctor's Avatar
harleydoctor
I totally agree, I went with the C 6 shifter and couldn't be happier..............
To c5 Hard To Shift
