Crazy Seat Controls
Old Jan 4, 2026 | 08:10 PM
chasboy's Avatar
chasboy
Oldtimer
Default Crazy Seat Controls
On my previous C5's the seat controls worked perfectly. In the case of my latest one, as Mickey in the Rocky movies said: "they gotta hundred pounds of brain damage"
I know very well how to set seat positions, etc. However, nothing seems to follow logic, retain the setting made, or to remain in the position specified. In addition, when I try to move the seat using the seat buttons, they stop periodically no matter how long you hold them. I have to release and start again and the movement is frequently no more than 1/8"....The steering wheel moves into position most of the time, but the "easy entrance/exit feature works sometimes and never predictably. I'm taking the driver's seat out to work on something else but I was wondering if I should check the condition of the switch internals and perhaps my ground points. If ANYONE has any suggestions I would appreciate it greatly.
Old Jan 6, 2026 | 02:58 PM
chasboy's Avatar
chasboy
Oldtimer
Bump.
On a similar note does anyone know if one can bench test a driver’s seat out of the car? I have a power supply and other 12 volt sources.
Old Jan 6, 2026 | 03:33 PM
tabbruzz's Avatar
tabbruzz
Not sure if you changed the seats or not, but there are different wiring harnesses. The incorrect one will cause many of the issues mentioned...
Old Jan 6, 2026 | 05:54 PM
chasboy's Avatar
chasboy
Oldtimer
Wow. thanks, AFAIK they are original to the car.
To Crazy Seat Controls
