Jacking pucks......
Old Jan 9, 2026 | 11:56 AM
WindHam's Avatar
WindHam
Originally Posted by lucky131969
So you jack it up on the painted rocker covers?
Nooooo. There is a little cutout where the pucks usually go.
Old Jan 10, 2026 | 02:16 PM
redzg's Avatar
redzg
Originally Posted by WindHam
I just use a piece of 2x4 wood to keep the jack stands from marring the paint on the frame. Racing jack just goes in raw because there is no room to put anything in between. Car scrapes over everything anyways ¯\_(ツ)_/¯
The problem with wood chunks or even aluminum and rubber twist lock pucks in the trunk or well is that if you need to lift the car while out and about for any reason you have to trust the weenie doing the lift can comprehend simple instruction -- which they can't. A bright red or blue "lift here" bobbin on the bottom of the car is pretty easy to identify. Though, I must admit, I've also thought about using some vinyl to mark the lift points, much like military aircraft munition lift points are marked.
Old Jan 17, 2026 | 09:56 AM
vito02's Avatar
vito02
Is there anyone here who leaves their lifting pucks in at all times? If so, what brand and where did you buy them? ...
I got mine from Southern Car Parts. SKU LP001 The pucks are "plastic" and snap into place. So far after a couple years they are still there.
Old Jan 18, 2026 | 01:34 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Hmm. I've never considered the permanently mounted units before. I try to avoid anything which would wear into paint up here in the northeast for corrosion reasons. I was sitting here thinking yeah I'm still fine with my ancient homemade pucks, but I then I thought maybe slapping a layer of EPDM on the back of the leave-ins would be sufficient for those aluminum pucks.
Old Jan 18, 2026 | 06:06 AM
chasboy's Avatar
chasboy
Oldtimer
Tusc, where would the contact area be with the paint, where the puck touches the frame? The aluminum ones are bolted on…that plus the EPDM would eliminate any movement that might wear the paint on the frame. The plastic ones I have are so light I doubt there would be any problem with paint contact. Unless I’m misunderstanding something?
Old Jan 18, 2026 | 08:12 AM
Tusc's Avatar
Tusc
Yes the frame coating. Sorry. Not paint on a body panel.
Old Jan 18, 2026 | 09:56 AM
chasboy's Avatar
chasboy
Oldtimer
NP. I just put new plastic leave-ins and they are not as snug to the frame as my last set. If it ever warms up here I’ll sneak some RTV in the gap so they don’t move around.
Old Jan 18, 2026 | 10:39 AM
vito02's Avatar
vito02
I too would be concerned re galvanic action if aluminum-alloy pucks are permanently installed, especially if road salt is a factor.
