2003 Z06 code P1415 help
Old Jan 16, 2026 | 02:32 PM
Mikec5newbie's Avatar
Mikec5newbie
2nd Gear
Default 2003 Z06 code P1415 help
Hello,
1st of all, I am 65 years old and new to Corvette's, and I absolutely love my 2003 C5 Z-06.
I am trying to smog in California and need help. I had code P1415 to which I 1st made sure pump was blowing. Then I sprayed throttle body cleaner and a little WD40 into the hose going to check valve followed by compressed air and repeated a couple times. I believe I loosened the check valve because the code has not come back after about 130 miles and many cold starts. The problem is, the secondary air system monitor is still showing "incomplete" after many more miles and many cold starts. I need to get the smog done ASAP, so any help you have will be much appreciated.
Old Jan 16, 2026 | 04:40 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Your age doesn't matter but in most states you are allowed to have 1 monitor not complete.
Old Jan 16, 2026 | 07:32 PM
C5 Diag's Avatar
C5 Diag
Old Jan 17, 2026 | 06:49 PM
Mikec5newbie
2nd Gear
This is very helpful, thank you so much.
To 2003 Z06 code P1415 help
