Base Manual C5 Corvette no-start issue
I’m dealing with an intermittent no-start issue on my C5 Corvette. Sometimes it starts normally, other times it simply refuses to start (when I turn the key there is no crank, just all the lights going out for 0.5 seconds). The problem seems random and not clearly hot or cold related. Battery voltage looks fine and there are no persistent warning lights.
So far, I’ve replaced the ignition switch and I’ve checked the starter, but the issue is still there. Before replacing more parts, I’d really appreciate any advice or insight into common C5 causes or what I should check next.
Thanks in advance.
