About to bug up
Old Feb 2, 2026 | 11:36 AM
namvet6869's Avatar
namvet6869
Default About to bug up
Installed a radio from Reversion Raceworks and having problems with the radio resetting itself. When I connect a trickle charger to the battery, after awhile the radio will reset. Don't lose any pre-programed stations but the time will reset. Seems this only happens when a trickle charger is connected. Been in touch with Reversion and they are puzzled and so am I. Reversion has been very helpfull in trying to solve this problem. Any suggestions would be very much appreciated. Even tried a different charger with the same results. Thanks Rich
Old Feb 3, 2026 | 11:07 PM
Moved to C5 Tech. If you do not get any helpful replies there, try posting in the Audio/Electronics Section.
