Code help B0502, B0507 and P1153 only codes
Old Feb 3, 2026 | 07:41 AM
goatkeeper's Avatar
goatkeeper
Default Code help B0502, B0507 and P1153 only codes
Hello and thanks for helping!
2002 Z06. I have these three codes and I am struggling with finding the issue. I replaced the O2 sensor. I replaced the burnt sockets on the DRL's. Engine stays in open loop and the dash light flicker unless the relay (do not remember which of the 2 relays I pulled) is pulled, then no front turn signals.
I suspect these are related and there is a short to ground. Can someone suggest the most probably location to begin my search? I do not have access to a lift. I struggle with electrical issues to begin with, but I do have a good DMM and can halfway use it...HAHA. I do have shop manuals.
Thanks for any help you can offer.
Jimmy Carter
Old Feb 4, 2026 | 01:47 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you have the shop manuals have you followed the flow charts ???...if you didn't all 3 DTC's are below...take your car to an auto electric shop if you are weak in electrical.unfortunately we can't diagnose this for you.
Old Feb 5, 2026 | 07:45 AM
goatkeeper's Avatar
goatkeeper
Thanks for replying. The manual explains the procedure, but in this case without a Tech 2 it is no help.
When you choose to live in a rural area, as we do, the options are limited. I'd have to trailer my car an hour and half to a town large enough which might have a component electrical automotive shop.
I've learned in the past, often times forums are a wealth of information. By posting, I hope someone might have had a similar issue and would be willing to share their experiences.
To Code help B0502, B0507 and P1153 only codes
