Difficulty Shifting into 1st Gear
Old Feb 6, 2026 | 08:38 PM
BlakeJ310's Avatar
BlakeJ310
Cruising
Default Difficulty Shifting into 1st Gear
Hello, I just wanted some help about my transmission. Whenever I am in neutral going into 1st gear, it sometimes does not want to engage and I would either have to put it back in neutral, let the clutch out, clutch in then go into 1st (which it does not work sometimes) or I would have to shift into 2nd then try shifting into 1st which also does not work sometimes. I did read in the manual that the T56 is known for this issue but I was wondering if there is any other way to help fix it because it can be frustrating to deal with when at a red light.
Old Feb 7, 2026 | 10:46 AM
mmartinez's Avatar
mmartinez
There is a shifter alignment you could try, a internet search for c5 corvette shifter will bring up lots of results. The transmission itself may have to be removed and inspected for damaged components, and lastly the clutch may not be fully disengaging when shifting. Good luck.
Old Feb 8, 2026 | 11:22 AM
Supercharged111's Avatar
Supercharged111
Mine was worse when warm. A new synchro fixed it right up.
Old Feb 8, 2026 | 11:29 AM
helga203's Avatar
helga203
If this car is new to you. This is normal will it shouldn't be normal but when your talking c5's it's normal. Just wait you'll start having engaging into reverse problems also. GL
To Difficulty Shifting into 1st Gear
