wheel hop
Old Feb 9, 2026 | 11:30 AM
goodtogo32's Avatar
goodtogo32
Default wheel hop
Does anyone have a cure for wheel hop? I've installed a transaxle brace from HPI, installed Bielstien shocks (B6) and replaced sway bar bushings. It has diminished quite q bit, I seen rear housings destroyed by wheel hop so I'm determined to fit it.
Old Feb 9, 2026 | 07:22 PM
Missileboy's Avatar
Missileboy
What tires and air pressures are you running?
Old Feb 9, 2026 | 08:07 PM
CFight's Avatar
CFight
What's your power, gear ratio, ride height, rim size, tire compound, runflats?
Old Feb 9, 2026 | 09:44 PM
vette4fl's Avatar
vette4fl
Old Feb 9, 2026 | 09:48 PM
BHauber's Avatar
BHauber
New tires if more han 5 years old.
Old Feb 9, 2026 | 11:11 PM
Moved to C5 Tech.
Old Feb 12, 2026 | 04:45 PM
vette4fl's Avatar
vette4fl
Cure needed! 😀
Old Feb 12, 2026 | 11:21 PM
goodtogo32's Avatar
goodtogo32
I'll try to keep it short on the mods. Vararam forced air, headers, heads were cc'd and polished, new springs keepers and retainers, 3:91 gears, dyno tuned, HPI trans axle brace, Bilstein B6 shocks (I know I should have put on coil overs), tires are continental Xtreme contact (two years old) running 40 psi, has 15K miles on the car. Best time was 11.47 with a lot of hop.
Old Feb 13, 2026 | 02:19 AM
vette4fl's Avatar
vette4fl
Why 40 psi?
Old Feb 13, 2026 | 06:47 AM
goodtogo32's Avatar
goodtogo32
Sorry for typo, I meant 30 of course.
Old Feb 17, 2026 | 12:57 PM
jjjery13's Avatar
jjjery13
Cruising
Absolutely no help to you, but maybe someone else!
I had terrible wheel hop. Changing the worn out factory shocks with B6's 100% cured it for me.
Old Feb 17, 2026 | 01:34 PM
arthursc2's Avatar
arthursc2
tires 22-24psi cold will help a lot. I shoot for 28 hot on a 315/30r18. Yes I drive on the street like that too. Yes its fine. Yes the car hooks. Yes it corners really well
Wheel hop is generally a bushing problem- I would start looking at delrin or polyurethane bushing replacements
Also check the rear spring and make sure the pads and bolts are in good shape with equal preload
what diff brace do you have? dumping the oem one for *insert favorite brand here* bar-types will help control drivetrain twist
Old Feb 17, 2026 | 03:46 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
C5 drivetrain is prone to wheel hop because of the single center diff mount. I tried a firmer hinson mount, coil overs, played with air pressure and tires. Finally broke the output shaft on the trans and part of the internals of the diff. Went C6Z output shaft and C6Z diff with a trans/diff brace and haven't had an issue since.
The hinson mount transmitted a lot of NVH into the cabin as did the t-bar mount
Old Feb 17, 2026 | 05:13 PM
goodtogo32's Avatar
goodtogo32
I have a HPI transaxle brace that I installed myself. It cut the hop down a lot, but I'm shooting for 100%. The car was in storage for 19 yrs due to the first owner almost losing his leg to blood clots. I got it with 9k miles. It has some engine work done and a 3:91 gear installed. I don't know how he did it but it turned a 11.47 quarter mile with all the hop with the factory trans mount. He said he had to take it easy on the launch.
Old Feb 17, 2026 | 06:11 PM
arthursc2's Avatar
arthursc2
What diff mount are you running?
Old Feb 18, 2026 | 10:09 AM
goodtogo32's Avatar
goodtogo32
Like I said, HPI trans axle brace. It replaces the BS diff mount the factory gives you. center bolt to diff with exstended arms with rubber snubber to frame.
Old Feb 18, 2026 | 01:58 PM
arthursc2's Avatar
arthursc2
This is what I thought you meant when you said "trans axle brace"
To wheel hop
Old Feb 18, 2026 | 02:51 PM
goodtogo32's Avatar
goodtogo32
No, this what I installed,
For C5 for CORVETTE HPI TRANSMISSION BRACE TRANS MOUNT DIFFERENTIAL
For C5 for CORVETTE HPI TRANSMISSION BRACE TRANS MOUNT DIFFERENTIAL LS1 5.7 LSX
Old Feb 18, 2026 | 02:58 PM
arthursc2's Avatar
arthursc2
without going to C6 cradle and diff side plates, that is the best option
How are your motor mounts? are they oem or replacements?
Old Feb 18, 2026 | 09:06 PM
goodtogo32's Avatar
goodtogo32
OEM and there are in good shape. I don't see where a front motor mount would have any effect on the rear wheel hop anyway. Just FYI at this point only the right rear wheel hops. Of course I don't have eyes on the left side but you can feel just the right side.
