C5 suspension help
Old Feb 17, 2026 | 07:51 PM
REDXIII's Avatar
REDXIII
3rd Gear
Default C5 suspension help
Hey all. My 2000 c5 rides like a covered wagon on a rocky trail. I’ve replaced shocks with bilstein b6, tires are newer non run flats. I’ve replaced sway bar bushings and moog stabilizer bar links. Should I replace the ball joints and control arms? New sway bar? It’s mostly bumpy in the rear. Let me know what you guys have found to smooth out the ride a bit. Sometimes I don’t feel stuck to the road when I’m getting on it a bit and the road isn’t perfect. Any help is greatly appreciated.
thanks!
Old Feb 17, 2026 | 08:22 PM
Ltngdrvr's Avatar
Ltngdrvr
Bilsteins are not soft ride.
Sway bars and links won't change the ride, except when cornering hard.
Is this a Z51 car?
Mine is and it rides pretty rough too.
Could change the rear spring to a base soft ride spring.
But, I am finding that the ride is sort of the nature of the beast.
There's always coilovers, but good ones are pricey.
Old Feb 17, 2026 | 08:27 PM
REDXIII's Avatar
REDXIII
3rd Gear
It’s just a base. Good to know they are all kinda rough before I dump money into it. Maybe the b6’s weren’t the best choice.
Old Feb 17, 2026 | 09:47 PM
vette4fl's Avatar
vette4fl
I had the same experience with the B6; really firm!
I installed C6 Z51 sway bars front and rear and the ride smoothed right out. I don’t know why, maybe it shouldn’t matter, but mine was instantly day and night better, way better.. Now it’s not a Crown Vic ride, but pretty close to a stock OEM suspension that corners really good!
An alternative is C6 Z06 shocks. Many swear by them.
Old Feb 17, 2026 | 10:07 PM
REDXIII's Avatar
REDXIII
3rd Gear
I may look into that. Thanks for sharing!
To C5 suspension help
