Steering lock and charging system
Old Feb 22, 2026 | 08:12 PM
Petcelman's Avatar
Petcelman
Default Steering lock and charging system
Well I am very new to this forum. I have learned a thing or 2 though. I had to typical steering lock and charging system scroll at the bottom of the dash. Since I am also new to this car I read that the answer may be as simple as a new AC Delco factory new alternator. I looked and eventually found one. I installed it today and voila! All the electrical gremlins vanished. I don't know how many brand new alternators there are for this particular application, but it can't be very many. I got lucky. Just FYI I am a retired tech and shop owner in the bay area (now residing in the Reno NV area) I appreciate all the tech info on this site, thanks.
Old Feb 23, 2026 | 12:25 AM
mmartinez's Avatar
mmartinez
Many problems occur when there is a low voltage condition on c5's, more so then on outher vehicles.
Old Feb 23, 2026 | 04:13 AM
Petcelman's Avatar
Petcelman
My C5 was charging at just above 14.3 volts and never wavered. I'm thinking I should try to find another alternator.
Old Feb 23, 2026 | 09:07 AM
Gordy M's Avatar
Gordy M
Check you battery with a tester with the car off, you should have minimum of 12.5V and also check the CCA and other items and compare it to the new battery specs. Should be clowe to thathose specs
To Steering lock and charging system
