Traveling cross country turned on high beams and then went back to low and dead, no lights, any ideas. High beams work but no lows and of course ticking off all the truck drivers.
Temporarily switch the low beam harness with the high beam harness. That will keep other drivers from giving you the finger. :yesnod:
Then if you look in your manual, I believe there is a layout of relays along with fuses. You should be able to find the headlight relay and possibly swap it for another relay to test if the relay went bad. :yesnod:
