99 frc........
Old Mar 3, 2026 | 04:20 PM
clutch1's Avatar
clutch1
Default 99 frc........
what tool do I need to pull my steering wheel....Is there one made just for the C5 corvette?.........John.
Old Mar 3, 2026 | 04:38 PM
Ltngdrvr's Avatar
Ltngdrvr
A video guide, produced by yours truly!
Old Mar 3, 2026 | 05:00 PM
Risk Bayless's Avatar
Risk Bayless
I did mine a few weeks ago. I used a steering wheel puller with the j hooks for part of the process. I also soaked the steering wheel nut in PB Blaster and tapped it with a hammer every so often to loosen up the gunk holding it on. All of that and some gorilla arming it for a day and a half and it came off.
Old Mar 4, 2026 | 11:52 AM
clutch1's Avatar
clutch1
what is the name of the puller?
Old Mar 4, 2026 | 01:43 PM
Ltngdrvr's Avatar
Ltngdrvr
Name? You mean besides steering wheel puller???
Just have to make sure whichever one you get has the "J" style GM puller hooks.
I got mine on the loaner program from AutoZone, so it didn't cost me anything.
Old Mar 4, 2026 | 03:40 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
This is the one you need.
https://www.autozone.com/p/oemtools-steering-wheel-puller-57182/555516?spps.s=4462&cmpid=LIAS:EN:AD:AL O:GOO:TRS:SHO:OTE:GEN:NA:ALA:NA:NA:NA:NA :NA:NA:NA&gclsrc=aw.ds&gad_source=1&gad_ campaignid=22356757832&gbraid=0AAAAADkco VuZZOQkdCKecd8A2vV0zb7rB&gclid=CjwKCAiAz Z_NBhAEEiwAMtqKy0ImbsJxp49nihjo1X8rjLYPT xpu5dV0NylhBzgsLMK6jeJi6BKUeRoCK80QAvD_B wE
Old Mar 4, 2026 | 10:51 PM
Moved to C5 Tech.
Old Mar 9, 2026 | 09:57 AM
clutch1's Avatar
clutch1
Thank you.....I guess when you dont do the job you wont know the Name.....Got mine from Auto Zone....Thank s..........................
Old Apr 24, 2026 | 10:07 AM
clutch1's Avatar
clutch1
Thank you................
Old Apr 24, 2026 | 02:08 PM
G_Loc's Avatar
G_Loc
Good luck getting it off! Mine would not budge. I ended up leaving the puller installed and under tension for a while (15 minutes? an hour?) with the splines soaking in PB Blaster. Eventually it popped off on it's own
Old Apr 24, 2026 | 03:31 PM
Ltngdrvr's Avatar
Ltngdrvr
oops.................................... .....
To 99 frc........
