C5 Engine Maintenance
Old Mar 12, 2026 | 05:39 PM
KyleDrivesC5's Avatar
KyleDrivesC5
Cruising
Default C5 Engine Maintenance
Hello everyone!
I'm going to be pulling out the motor on my 2001 C5 base model soon. I'm planning to replace the rear main seal (damm oil leak), replace the harmonic balancer, check the spark plugs and fuel injectors, check for any other leaks, and clean the engine.
Is there anything else I should replace/check while the motor is out? Thinking about adding long tube headers.
Have a great rest of your day!
Old Mar 12, 2026 | 08:10 PM
hyperv6's Avatar
hyperv6
Front seal, water pump and the idler pulleys. .
Old Mar 12, 2026 | 09:05 PM
Tommy Bahama Fan's Avatar
Tommy Bahama Fan
If the engine is out, I'd probably spend the extra 20-30$ and 30 minutes for new intake gaskets.
Old Mar 12, 2026 | 09:11 PM
DDaaryl's Avatar
DDaaryl
The oil pressure sending unit is a part that frequently fails. Replace it and consider relocating it which is common.
Old Mar 12, 2026 | 09:21 PM
vette4fl's Avatar
vette4fl
Remove the A.I.R system. All the hoses and gear will always be in your way.
It would also be an ideal time to swap in a cam.
How many miles on the engine?
Old Mar 12, 2026 | 09:23 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Look at the "refined" rear main seal.
https://www.corvettepartscenter.com/...rear-main-seal
Old Mar 12, 2026 | 09:31 PM
Tommy Bahama Fan
I second that. It's amazing how much this opens up the engine bay.
And if you really want to make hay, put a newer valley cover (2004 - ls6) on it and you can get rid of couple feet of PCV piping.
Old Mar 12, 2026 | 11:56 PM
KyleDrivesC5
Cruising
I've got 112,000 miles on the engine. I was thinking about a cam, but I want to keep the great gas mileage the autos have. The only reason I would do a cam would be for the sound, not the power.
Old Mar 13, 2026 | 12:33 AM
vette4fl's Avatar
vette4fl
Well to get a choppy sound, you would lose gas mileage. So there goes the cam and also any gear change or stall convertor, lol. Maybe a nice double din radio setup 👍
Old Mar 13, 2026 | 03:22 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Supercharger.
Your wife will never know.
Old Mar 13, 2026 | 03:40 AM
KyleDrivesC5
Cruising
Originally Posted by Tusc
Supercharger.
My wallet will however. (Also I'm 19 and happily single )
Old Mar 13, 2026 | 06:26 AM
FinnishFireball's Avatar
FinnishFireball
How about changing the spark plugs instead of just "checking". Pretty cheap an easy and then you know they are new.
Old Mar 13, 2026 | 06:29 AM
hyperv6's Avatar
hyperv6
If the intake is off replace the knock sensors
Old Mar 13, 2026 | 07:25 AM
Trickskier's Avatar
Trickskier
Supercharger.
Old Mar 13, 2026 | 12:13 PM
KyleDrivesC5
Cruising
for sure the plan
Old Mar 13, 2026 | 12:17 PM
Tusc's Avatar
Tusc
By all means enjoy stacking the body count then. But know that I didn't find out until 46 that life doesn't begin until you're a dad. Just make sure you don't waste too much time on girls who are not the one.
Solid choice on a C5 as a starting point!
Old Mar 13, 2026 | 12:31 PM
ddt's Avatar
ddt
Kudos for taking on a rather large project. When I was 19 I had the energy but not the experience. Often times I ended up "fixing" something and making it worse. That however was just me.Good luck with your project.
To C5 Engine Maintenance
Old Mar 16, 2026 | 04:01 AM
FLYINBY's Avatar
FLYINBY
I had the clutch replaced, 2nd gear lockout removed and the torque tube rebuilt when the main seal was done. If you're concerned about heat (at the track?), you might want to put some insulation somewhere around/up under the torque tube I think it was I read. checked rear differential
Old Mar 16, 2026 | 09:55 AM
Trickskier's Avatar
Trickskier
If I remove the A.I.R. System. Does this have to be plugged on the exhaust manifold?
Old Mar 17, 2026 | 11:34 PM
Moved to C5 Tech.
