Caliper cover issue
Old Apr 6, 2026 | 09:39 AM
bnttadm1's Avatar
bnttadm1
Default Caliper cover issue
Hey everyone,
I have a 2001 C5 Corvette and recently picked up a set of MGP caliper covers (red with silver C5 script) to replace the ones currently on the car. After installing them, my mechanic found that the stock wheels are rubbing against the covers.
Has anyone run into this before? Would a 5mm spacer be enough to fix the clearance issue, or is there a better solution?
Appreciate any advice—thanks!
Old Apr 6, 2026 | 10:25 AM
lucky131969's Avatar
lucky131969
Originally Posted by bnttadm1
Hey everyone,
A few things. There are threads from a decade+ ago discussing issues with these covers.
Are you the original owner of the car? The center caps on your wheels are not original for 2001-2004, and are typical to aftermarket thin spokes....typically steel and not aluminum.....which could make the clearance issues worse.
Old Apr 6, 2026 | 11:07 AM
Gorn Captain's Avatar
Gorn Captain
Take those nasty things off and paint your callipers. Those things are tacky. Paint and You’ll have a lasting result and people wont talk behind your back.
Old Apr 6, 2026 | 11:50 AM
Lowend's Avatar
Lowend
You won't know if the 5mm spacer will clear the caliper cover until you put it on. But looking at the mark it looks pretty shallow so I'd think you'd be ok.
That said, I don't like wheel spacers
I'll join the chorus here, that cover is already damaged, I'd just take them off. Those things aren't fooling anyone who knows what they are looking at. I always worried about them retaining heat.
I'll suggest a set of powder coated calipers from TPS
https://www.tpsmotorsports.com/powder-coated-calipers
They looks great, and won't cause other issues
Old Apr 6, 2026 | 01:28 PM
Ltngdrvr's Avatar
Ltngdrvr
Those covers are crap.
My car had them on it, very first thing I did to my car when I got it was take them off.
Old Apr 6, 2026 | 08:19 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
To each his own but those things are I'd get rid of them and paint the stock calipers.
To Caliper cover issue
