Dart LS next block
Old Apr 8, 2026 | 02:44 PM
Darkbluecoupe's Avatar
Darkbluecoupe
Default Dart LS next block
Looking to build a 427 for my car,Will the factory accessories bolt to a dart block or does everything need to be fabricated?I know they will accept the factory covers but wasnt sure if this is anything that wouldn’t be easy swap.
Old Apr 10, 2026 | 05:08 PM
LS7 destruction's Avatar
LS7 destruction
8th Gear
All the factory parts will bolt to a Dart Next Gen. good luck with your build.
Old Apr 12, 2026 | 04:24 PM
NSFW's Avatar
NSFW
I have an aluminum Dart block in my car. The only quirk is that I don't have the LS1/LS6 "resonant" knock sensors, but I have to admit that I didn't try an LS1/LS6 valley cover.
I think I'm very close to getting LS3-style "flat response" knock sensors working, and I should know more in 3-4 weeks. (I had some titanium intake valve lash caps part ways with the valves...)
Old Apr 13, 2026 | 09:08 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Are you still running a 411 ECU or is this with a Haltech?
Old Apr 15, 2026 | 02:13 AM
NSFW's Avatar
NSFW
I switched from the 411 / P01 / red-blue PCM that came with my 2002 C5, to a 243 / P59 / green-blue PCM like you'd find in a 2004 C5. That requires moving an alternator wire from 52/red to 75/green (same connector, requires new colored sleeves, or you can shave the ridges off of the red sleeves).
There flat-response sensors need to be wired to different pins than the resonant sensors, and some tables need to be updated in the tune. I started a thread about it at PcmHacking.net but it's paused while I wait for my heads to get rebuilt. Once I confirm that it really does works, I'll rewrite the first post to contain everything you'd need to know.
https://pcmhacking.net/forums/viewto...113096#p113096
To Dart LS next block
