Fuel Pressure Gauge help
Old Feb 22, 2003 | 09:01 AM
402Sam's Avatar
402Sam
Default Fuel Pressure Gauge help
I going to get a electrical fuel pressure gauge to put into the pillar pod. How would I go about hooking it up. I.E. Where do I run the wires to and what do I hook them up to. Is there a wire somewhere that I can tap into?
Old Feb 22, 2003 | 10:59 AM
hrdtopv8's Avatar
hrdtopv8
Default Re: Fuel Pressure Gauge help (sprayedc5)
Depending on the type of gauge the wires you would need to tap into are:
-hot wire (12v+ ignition)
-ground (any source of good ground)
-light (tap into instrument light wire)
-electrical sending unit
On the fuel rail closet to the alternator you should see a pressure port that is used to test the psi of the fuel coming into the engine. This is where you connect your electrical sending unit too.. :cheers:
