Clunk in rear end
Old Apr 14, 2026 | 12:44 AM
SemDaMan's Avatar
SemDaMan
Default Clunk in rear end
I’ve read through a few forums and seen a lot of different ideas, but I’m hoping someone might have some solid direction. I haven’t done a deep inspection yet, but when I put the car in reverse I get a clunk, but only once I start moving, not when I shift into gear.
So far, the only thing I’ve tried is loosening the axle nuts, lubricating them, and re‑torquing them. I did buy a cheaper non‑OEM rear left axle, but it looked slightly smaller, so I’m wondering if I should replace it with a proper OEM one.
I can also replicate the clunk by pushing on the car while it’s parked, and I do notice a little bit of play. Has anyone run into this before or have ideas on what to check?
Old Apr 14, 2026 | 06:19 AM
Pipedream's Avatar
Pipedream
MANY, myself included, have had this problem and I am almost positive the factory part is no longer made.
Here is a link for a TSB talking about a fix for 2004 C5s.
https://www.corvetteforum.com/forums...m_content=post
Old Apr 16, 2026 | 08:17 AM
Joe Scafide's Avatar
Joe Scafide
Default Clunk
Try tighten the rear shocks that was my problem
To Clunk in rear end
