EBCM repair tips
Old May 10, 2026 | 12:30 PM
Gorn Captain's Avatar
Gorn Captain
Default EBCM repair tips
Yesterday I did the solder repair with success. Ready to reinstall I’m looking at those damn screws and how I’m going to get them in without dropping them 59 times and losing my mind.
well, brain has a light bulb go off. The screw hole flanges on the module are fairly thick. I grabbed some (1/8”?) silicone tube I had handy and cut small lengths the thickness of the flanges. Thread that on the screws and stuff them in the flanges. The screws stay in place and you can just reach in with the T20 and drive them home. So easy.
Most videos I watched showed 1/4” bolt to pry the cover off the module. Way too big. I tapped a #10-32 and drove it in with my drill torque set at 7-8 to slow the progress. Worked great.
Old May 11, 2026 | 11:40 AM
LeeinVA's Avatar
LeeinVA
Congrats on the repair!
Which " early" model year EBCM did you repair?
Thanks!
Old May 11, 2026 | 11:45 AM
Gorn Captain
Thank you! 2001. I have no bark left on my knuckles!
Old May 11, 2026 | 01:27 PM
LeeinVA's Avatar
LeeinVA
Old May 11, 2026 | 04:12 PM
jshanks's Avatar
jshanks
7th Gear
I put them on the Torx driver and wrapped around the top of the screw and driver with masking tape.
Old May 11, 2026 | 04:24 PM
Gorn Captain
Yup. That was my first plan, then I saw the loop of tubing hanging on my wall of junk and figured let’s try this.
Old May 11, 2026 | 04:51 PM
jshanks's Avatar
jshanks
7th Gear
Anything to make them stick to the screwdriver is the right way. I remember using Playdough back in the day.
To EBCM repair tips
