Not getting 12V at the underwood light socket
Old May 28, 2026 | 03:56 PM
jjc508520's Avatar
jjc508520
Default Not getting 12V at the underwood light socket
Installed a new underwood LED light and was barely getting any output from it. Measured the voltage at the socket with my meter and only 0.5. Checked fuse #2 in the foot well and surprisingly found it was “partially blown” - evidently conducting some electricity, but not all. I installed a new fuse and now I’m getting more voltage but still only 7.5. Any thoughts why I am not getting 12 - or is 7.5 what’s supposed to be there?
Old May 28, 2026 | 04:12 PM
jjc508520's Avatar
jjc508520
Lesson learned - better off to install the underhood light THEN install the fuse. It is very easy to blow that guy. I don’t know what size fuse is supposed to be in there - but went from a 10 to a 15 and things seem to be working OK now…..
Old May 29, 2026 | 08:20 AM
Gorn Captain's Avatar
Gorn Captain
yeah, just throwing a bigger fuse in isn’t a good plan.
You want to see voltage that the same as the battery voltage.
If it’s not, you have a problem. First step: Take your multi meter, disconnect the positive off the battery, measure your hot wire terminal on the light to ground away from the light for continuity, to check for a shorted hot wire.
Old May 29, 2026 | 09:15 AM
Moved to C5 Tech.
Old May 29, 2026 | 09:23 AM
lucky131969's Avatar
lucky131969
Damn. Good luck with that
Old May 29, 2026 | 09:54 AM
1Hotrodz's Avatar
1Hotrodz
First off, the LED light draws a minimal amount of current, putting a larger fuse in can cause a fire. Fuses are there to protect the wire, not the device. Sounds like you have a frayed wire somewhere most likely the Pos. wire. Did you check the voltage between the Pos. at the socket and the Neg. at the battery or Neg. at the socket? A difference (say at least 2 Volts) in voltage between checking the socket (Neg) and Socket (Pos.) and checking the Batt. Neg. and socket (Pos) would indicate a bad ground. And the fuse size should be shown on the fuse panel directory or on the actual fuse block.
Old May 29, 2026 | 10:21 AM
jcgunn's Avatar
jcgunn
The OEM socket has a mercury switch and is not compatible with LEDs. Try a conventional bulb and see if the problem is solved.
Old May 30, 2026 | 09:31 AM
1Hotrodz's Avatar
1Hotrodz
This is the first time I heard of that. How so?
Old May 30, 2026 | 11:33 AM
jcgunn's Avatar
jcgunn
The OEM socket has a mercury switch to turn on/off and a (10 minute?) timer to shut the light off when the hood is up for an extended period. LEDs don't draw enough current to make the circuit work correctly.
Old May 30, 2026 | 12:35 PM
Gorn Captain
Strange then why Corvette specific light & accessory suppliers list LEDs for the hood light.
https://www.vette-lights.com/products/1997-2013-c5-c6-corvette-under-hood-underhood-led-no-modification-to-housing
Mercury switches will make no difference to any load they supply. It’s just Liquid Metal in a glass capsule that moves to one end where there’s two contacts, thereby closing the circuit.
Old May 30, 2026 | 01:28 PM
jcgunn's Avatar
jcgunn
https://www.vette-lights.com/product...ion-to-housing
Well, maybe it's the timer part of the circuit. All I know is generic LEDs don't work right. Now the ones you are listing might have a built in resistor to solve the problem.
Old May 30, 2026 | 03:43 PM
lucky131969
10 minute timer, and in the lamp assembly? No and no.
The underhood light circuit is controlled/monitored by the BCM and will shut it off after 15 minutes.
To Not getting 12V at the underwood light socket
