Electrical Gremlin Solved!
Old May 31, 2026 | 01:20 PM
2002Houston's Avatar
2002Houston
1st Gear
Default Electrical Gremlin Solved!
I was plagued for months with intermittent NO COMM on multiple systems.
I finally figured it out,...I jiggled the key and everything lit up normal.
So, I have to remove and inspect/clean contacts on the ignition switch/connections.
I have a new HUD projector to install anyhow, so I'll do both on dash teardown.
At least i narrowed down the problem,...woo hoo!
Old May 31, 2026 | 03:01 PM
Ltngdrvr's Avatar
Ltngdrvr
I feel sure that many electrical issues are the fault of the ignition switch, seems to be a failure prone design.
