By-pass oil filter systems??
Old Feb 23, 2003 | 04:53 PM
NJblack99coupe's Avatar
NJblack99coupe
Default By-pass oil filter systems??
I was wondering if a by-pass oil filter system could be used on our cars. It's my understanding that generally they are used on trucks. I was watching a show one day that showed a truck with it that had about 2k miles on the oil, and when the whiped the dipstick it looked almost like new oil. I know the oil on my car looked dark pretty quick so the oil.... So is it possible to install/use like a amsoil by-pass oil filter in addition to the full flow filter on our cars.
And if it is possible would it be beneficial(i assume the oil would be a lot cleaner but would there be negative sideeffects by having 10% of the oil in the by-pass filter)?
Old Feb 23, 2003 | 08:27 PM
vettenuts's Avatar
vettenuts
Default Re: By-pass oil filter systems?? (NJblack99coupe)
I have looked at the same thing. I think there is a slight drop in oil pressure with these systems, but am not sure. I also looked at a remote filter so that you can put on a larger filter. However, that would mean I couldn't use the AC Delco Ultraguard filter which I do like. Might want to also pose this question on the "Bobistheoilguy" forum in the oil filter section.
Old Feb 24, 2003 | 10:43 AM
carpe dm's Avatar
carpe dm
By-pass systems are great. However, the location of the LS1 oil filter makes adding an adapter/oil lines/etc. difficult, especially if you have a lowered car. Probably not worth the potential grief. :)
To By-pass oil filter systems??
