Driving to wally world an hour ago and BAM! Check Engine ??
I have done nothing since last drive. Just sitting at a light, and she lights up.
See my sig for mods.2001 A4 12,500 miles. Now What??
I just checked codes.I got PO172H and PO175H Any info would be great.
Tom, when did you pull the screen? Plus, you were just working around the air bridge. As mentioned above, check carefully for air leaks in the intake area.
A lean condition can be caused by unmetered air making it past the MAF - in other words, a leak. Go over the intake system from the air filter back and double ceck every connection carefully to rule that out first.
