Hypertech question
Old Feb 25, 2003 | 08:56 PM
Stevedore's Avatar
Stevedore
Active Streak: 90 Days
St. Jude Donor '03-'05-'06-'07-'08,'11 thru '17, '21
Default Hypertech question
I've read that the Hypertech can adjust A4 shift points & firmness. I'd like it if mine shifted at somewhat higher MPH in each gear, especially at part throttle. And I'd also like it if it dropped down a gear for passing, etc., without having to go WOT.
Will the HPP3 do these things for me, or are its shift point adjustments only effective at WOT?
I'd guess a Transgo kit would accomplish the same things, but I'm not sure I want to get into that.
Thanks,
Steve.
Old Feb 25, 2003 | 09:59 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
Default Re: Hypertech question (30yrwait)
The HPP3 is a waste of money IMHO.There are better options out there,i.e.LS1edit,predator,custom program.
just my.02.
Jerry
Old Feb 25, 2003 | 10:18 PM
clancy's Avatar
clancy
I did this very thing today to my car, but I used the LS1 Edit. I have no experience with the Hypertech, but the LS1 Edit worked great. :cheers:
Old Feb 25, 2003 | 10:56 PM
1g1yy's Avatar
1g1yy
I am using it on my '99 A4 coupe. It will allow you to set firmness ( speed ), and also to raise shift points but only at WOT.
Its primary use to me was in changing the fan turn-on temp. And also it will come in handy when I change from my 3.15 to 3.42 gears.
Buying it new is a waste of money IMO, because there are better options now for not much more money. But if you can be patient as I was and wait for a used one to come on sale for about $175, then it's not a bad deal. :cheers:
Old Feb 25, 2003 | 11:23 PM
lost's Avatar
lost
Default Re: Hypertech question (clancy)
I'm very happy with mine, adjusted all parameters that I was interested in, is simple to use, if at a later date I want to do more I'll go with Ls1 edit, which requires much more in the way of peripherals. I purchased mine used, off the forum and consider it one of my better investments.
Old Feb 26, 2003 | 12:56 AM
C5XTASY's Avatar
C5XTASY
Default Re: Hypertech question (lost)
:iagree:
To Hypertech question
