Steering wheel shake
Old Feb 26, 2003 | 08:18 AM
NassauBlue's Avatar
NassauBlue
Cruise-In VII Veteran
Default Steering wheel shake
On my trip to Mississippi, I noticed a 'shaking' in my steering wheel. This is what is happening: If I take my hands off the steering wheel while going straight, the steering wheel quickly oscillates left/right/left/right/left/right by about an 1/8 of an inch. The car will go straight on a flat road, wander right on a road crowned to the right, and wander left on a road crowned to the left.
Anyone ever experience this? Any ideas what the problem may be? It would sound like an alignment or tire issue, but the tires are new and it has been aligned within the past 1500 miles.
Thanks,
Raymond
Old Feb 26, 2003 | 08:37 AM
jeffh355's Avatar
jeffh355
Default Re: Steering wheel shake (NassauBlue)
Lost a wheel weight maybe?
Old Feb 26, 2003 | 08:39 AM
RED99HT's Avatar
RED99HT
I had the same issue a couple of years ago. The problem was the tires were not properly balanced when I put them on new rims. Take them back to the tire place and have them check the balance again.
Old Feb 26, 2003 | 09:16 AM
NassauBlue's Avatar
NassauBlue
Default Re: Steering wheel shake (RED99HT)
RED99HT,
Did the car body vibrate also? I've had the car up to 85 MPH, but didn't notice any vibration in the body of the car. I've notice the steering wheel shake as low as 45 MPH. It doesn't seem to get worse the faster I go. I'll get the wheel balance re-checked when I can. Hopefully before the 1200 mile trip home.
Raymond
Old Feb 26, 2003 | 09:26 AM
cscollis's Avatar
cscollis
You have bent or out of round rims. I had the exact same issue. You can try to rebalance but it may not be possible. I had to buy new rims.
Old Feb 26, 2003 | 10:27 AM
RED99HT's Avatar
RED99HT
Nass
The car did not vibrate at all, only the steering wheel. Like you said, it would become more noticeable after you get up to speed. I had the front wheels rebalanced and it solved the problem right away. If this does not help it may be a problem with your wheels.
Old Feb 26, 2003 | 02:08 PM
VetteDrmr's Avatar
VetteDrmr
Also, new tires can change their "balance" quickly as the tires "break in".
HTH,
Mike
To Steering wheel shake
