FLP header dyno results
Old Mar 4, 2003 | 04:01 AM
jmX's Avatar
jmX
Default FLP header and tuning dyno results
First, I had heads/cam/stock manifolds with MTI tuning. That is the blue line.
Then, I installed FLP headers, put 500 miles on the combo to give it time to adjust, and dyno'd. That is the red line. It had some knock retard due to too much timing in the program, and it also was going rich on the topend.
So, while sitting on the dyno, I dyno tuned it with LS1edit and my laptop, and that is the green line. It took 50 minutes to tune it to that by just editing 2 tables in ls1edit, and was pretty simple (I'd never seen the program until a couple days before I tuned it).
All dyno's were done through the stock Z06 mufflers.
(Click to enlarge)
All of my horsepower mods (head/cam/headers/intake manifold/tuning) were self installed, and all but LS1edit were purchased from http://www.ThunderRacing.com. Great folks over there. :cheers:
[Modified by jmX, 3:05 AM 3/4/2003]
[Modified by jmX, 8:24 PM 3/4/2003]
Old Mar 4, 2003 | 06:24 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Default Re: FLP header dyno results (jmX)
Great info!
Old Mar 4, 2003 | 07:38 AM
SwissVette_Joe's Avatar
SwissVette_Joe
THANKS very much, jmX, for sharing this valuable info. Sounds and looks very interesting. :cheers: :cheers: :smash:
I am still cracking my heads remaining grey-cells looking for a nice set of Headers.........
Joe. :seeya
Old Mar 4, 2003 | 08:57 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: FLP header dyno results (SwissVette_Joe)
DAMN....those are some GREAT increases!!!! :cool: :cheers:
did that include hi-flow cats or no?
Old Mar 4, 2003 | 08:58 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Nice gains!!! :cheers:
Old Mar 4, 2003 | 09:40 AM
add's Avatar
add
Nice gains! :cheers:
Old Mar 4, 2003 | 09:56 AM
SvenOdin's Avatar
SvenOdin
That's a nice gain Jon!
:cheers:
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Very nice gains.
When you program with LS1Edit on the dyno the PCM resets and all learned data is lost. With that in mind it might be a good idea to dyno your new tune again after PCM learning completes.
Old Mar 4, 2003 | 10:05 AM
SideStep's Avatar
SideStep
:cool: :cool: :cool:
Old Mar 4, 2003 | 10:21 AM
RWhite's Avatar
RWhite
Default Re: FLP header dyno results (SideStep)
Nice curves!!!! I do like the increases the long tubes give these cars. My TPIS showed similar constant gains across the power band as yours did.
When you used LS1 Edit, was one of the adjustments leaning out the fuel? How much did you lean it? I want to go back to the dyno and try to lean mine out just a little more now that the new headers are installed. I have only run it a 100 or so miles and I am sure it is still learning.
The LT’s really give you a true SOTP increase, no doubt!
Old Mar 4, 2003 | 10:25 AM
Patches's Avatar
Patches
Awesome, Jon. :cheers:
What tables did you edit and how much? Across the board or just certain cells?
Old Mar 4, 2003 | 10:48 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Nice gains jmX. :cheers:
What final max timing and AFR did you leave it tuned at?
[Modified by Godspeed, 9:48 AM 3/4/2003]
Old Mar 4, 2003 | 11:25 AM
kp's Avatar
kp
I like the Z06 exh/FLP/cats sound - its pretty stealthy until you nail it :) Dont be afraid to run the cats if you arent, I gained very little with them off but I honestly didnt tune for them being off since I dont drive the car like that. I also didnt really pick up anything with stingers (except for a lot of noise) so at my HP level the Z06 exhaust is awesome :cheers:
Old Mar 4, 2003 | 12:45 PM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
:cool: :cool: :cool: :thumbs:
Old Mar 4, 2003 | 01:11 PM
SoCal C5's Avatar
SoCal C5
Default Re: FLP header dyno results (Mean Green 2000)
The dyno sheet said no cats.
Old Mar 4, 2003 | 01:40 PM
johnnyC5's Avatar
johnnyC5
nice solid gains jmX
noticed your "RED" line was with no cats
was the "GREEN" line (with tuning) and no cats as well?
Old Mar 4, 2003 | 01:43 PM
dahoof's Avatar
dahoof
Great gains!! We need to hook up so I can check it out sometime!!! :cheers:
To FLP header dyno results
Old Mar 4, 2003 | 02:43 PM
jmX's Avatar
jmX
Thanks guys for the comments. I'll try to answer the questions.
First, both header lines are without cats. I do have high flow cats laying around and one day I'll throw them on, retune, and see what the difference is. Right now its just too expensive for me to keep tuning on the dyno every week :eek:
Second, flp's plus z06 catback sounds freaking great, I agree. It sounds racey, not loud and obnoxious like most of the headers/offroad/catback cars I've heard. Its all relative I guess.
As for tuning, I edited the PE table all across the rpm range (my ltrims seemed fine before I tuned so hopefully things wont drift too much), and I edited timing for the rows in the timing table that I normally see at WOT. The best power seemed to be had with around 27 degrees at peak torque, then fading up to 28.5 degrees by redline. Each car is different tho.
The final A/F ratio is on this graph here, its the RED line (the blue one shows how i was going rich after putting on headers)
Click to enlarge
BTW, the writeup for the install should be up by the end of the week, AND, I may get LG headers eventually just to see how they compare back to back against the FLP's...scientific purposes only of course. :lol:
Old Mar 4, 2003 | 07:30 PM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
So Jon,
First, let me complimnet you on your hard work doing these installs, and the writeup that goes with it. I personally do not like the writeup part my self, so when you do the LG Long Tube install, I plan to use your write up as a set of "installation instructions".
One of my concerns is that the benefit of the LS1edit fixed your tuning deficiencies and added 10rwhp to the test, but should not be attributed to the header increase.
You got 17 rwhp with the FLP header installation. And would you say that you could have gotten 10rwhp out of LS1edit regardless of when you tuned it, either before or after the header install?
I know this is on the edge of "political correctness", but I would say that you would have gotten 10rwhp from LS1edit tuning with or without the headers, and by doing the tuning after the header install, is being slightly misleading.
And in addition, you have it tuned to 13.5 A/F which is a tad on the lean side, without showing the A/F with the stock exhaust.
I am not trying to discredit anything that you say, but I come from a Mathematics and racing background that requires that changes be made on at a time, and when you make 2 changes, the order of the changes should not imply that the first change gets credit for both changes.
The way I see it, if you put my LG Long Tubes on this car, it cannot take advantage of the tuning gain, because that 10hp was already given by default to the FLP headers.
In our race car, if I put a new set of headers on, and then changed the carb, would we attribute the horsepower increase from the carb change to the headers?
Maybe if you remove the headers, and re-dyno it without retuning, you would get a more accurate horsepower number that could be attributed soley to the headers.
Thanks,
Lou Gigliotti
Just some food for thought
Old Mar 4, 2003 | 07:59 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Congratulations on doing the work yourself.......that is very rewarding. Good numbers.
