275 = fatter, less steering response, more wasted tread on the outside. Bigger sidewall = uglier (IMO). Nasty what sizes did you use on your c5 you had, post a pic of that baby she is sweet.
BTW what it really depends on is what kind of tire youre talking about. the same size tire in a different brand could be used for an entirely different purpose (for or rear). Porsches used to use a 265/35/18 on a 10.5 inch rim. It looked FAT on the rear. The more you can stretch the tire on the rim the better response you will get. Plus IMO it makes the rim look bigger too.
Last but not least if youre going to lower the car the 265s or 275s will look good. If you dont the smaller diameter of the 265 may make that gap look horrible. Go to tirerack and check the specs of the tire youre looking for. It will say the overall diameter... it should give you an idea how much of a difference there is. :cheers:
If its for the front : 265 :yesnod: Rear : 275 :yesnod:
