help removing exhust manifolds
Old Mar 6, 2003 | 09:24 AM
redrocketship's Avatar
redrocketship
St. Jude Donor '09
Default help removing exhust manifolds
Installing headers and I'm trying to remove the factory manifolds. I cant seem to break them loose from the head. All the bolts are removed. Tried prying from the bottom and the top. I can get one end to slid up and down, but it would break loose. They must have used superglue on these things :mad Ideas are welcome. Thanks
Old Mar 6, 2003 | 12:12 PM
jmX's Avatar
jmX
Default Re: help removing exhust manifolds (redrocketship)
there are *6* bolts per side, not five. Make sure you got them all. They should fall off once all are removed. There's nothing sticky about it.
Old Mar 6, 2003 | 03:46 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Look for the hidden one under the air injection tube boss. There are two very close to each other.
Old Mar 7, 2003 | 12:20 AM
redrocketship
St. Jude Donor '09
Default Re: help removing exhust manifolds (jmX)
jma and Andy, Thank you for responding, that was the problem. The one under the air tube. You probably saved me from breaking something. Thanks Again !!! :cheers: :cheers: :cheers:
To help removing exhust manifolds
