New Z06 wheel problem!!
Old Mar 6, 2003 | 09:45 AM
Guest
Guest
Posts: n/a
Default New Z06 wheel problem!!
I'm having new Z06 wheels put on my vette do I need new wheel sensor's?
to fit on Z06 type wheels?
:confused: Problem solved they didn't see the o-ring's
[Modified by ETVETTE, 10:01 AM 3/6/2003]
Old Mar 6, 2003 | 11:36 AM
hogurt's Avatar
hogurt
Default Re: New Z06 wheel problem!! (ETVETTE)
I have an '02 and I do not need different sensors. I believe that the sensors are configured for your car's computer (not wheel type).
So, I would assume that you do not need different sensors. :cheers:
Old Mar 7, 2003 | 12:32 PM
andreas g.'s Avatar
andreas g.
I HAVE A 2002, WITH OEM Z-06 WHEELS. I JUST REMOVED THE SENSORS, AND PUT THEM ON THE Z-06 WHEELS. NO PROBLEMS
Old Mar 7, 2003 | 03:07 PM
jrz01's Avatar
jrz01
Default Re: New Z06 wheel problem!! (andreas g.)
:iagree: Same story
Old Mar 7, 2003 | 10:53 PM
99 The Hard Way's Avatar
99 The Hard Way
Default Re: New Z06 wheel problem!! (jrz01)
I have a 99 FRC w/ 01 Z06 wheels. I cannot get the sensors to fit. They block the bead from setting down on the rim. I heard the newer style sensors work but the old ones need thicker (or just new) o-rings. Still working on this in another thread as where to get the o-rings. SCOTT :rolleyes:
To New Z06 wheel problem!!
