C1225 FIX?
Old Mar 8, 2003 | 03:17 PM
c5man99's Avatar
c5man99
Default C1225 FIX?
I got this code, LF check ABS, TC, Active.........with ABS & Traction instrument warning lights. I was told that this common when you change to braided brake lines. Anyone hear of this? The tech said his fix was to attach a ground strap! We replaced the hub.....no help.........any comments WILL be appreciated,
Old Mar 8, 2003 | 10:00 PM
Kenny94945's Avatar
Kenny94945
Default Re: C1225 FIX? (c5man99)
Check the wiring at the hub, the short harness where it clips on. Look for intermittent or broken wire.
Any line other than Goodrich could cause an interference problem.
Been there.
Old Mar 8, 2003 | 10:38 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Marc, the info about the ground strap is correct. However, some have posted that this did not cure all the cars in question. Where the ground strap did not work the only fix was doing away with the braided lines. :cheers:
Bob
Old Mar 8, 2003 | 11:51 PM
c5man99's Avatar
c5man99
Default Re: C1225 FIX? (16Again)
Thanks guy's.......that's what I get for listening to the "Experts" and getting Russell's. I still don't understand the "Interference" problem. This signal is not transmitted, like the tire pressure sensors, which work fine.
Bob, I won't be racing tomorrow.........Les will fill you in.
Old Mar 9, 2003 | 11:15 AM
TooManyIDs's Avatar
TooManyIDs
Goodridge owners have posted with the same problem, but fewer cases.
It's not exclusive to Russell's.
To C1225 FIX?
