Shake at 80 mph......
Old Mar 8, 2003 | 06:39 PM
JeffB's Avatar
JeffB
Default Shake at 80 mph......
My car seems to shake at 80 and higher :eek: When I let go of the wheel at lower speeds it tracks stright as a string. :) But when I get to higher speeds it shakes...Could this be just balance of the tires? :confused: I mean if it was out of line wouldn't it drift one way or the other? Or could it be that one wheel may be out of alignment? Tire wear looks even for all..Thanks for any help :yesnod:
Old Mar 8, 2003 | 07:36 PM
Norris's Avatar
Norris
Default Re: Shake at 80 mph...... (JeffB)
Sounds like an out of balance condition of at least one tire. I would have all four wheels rebalanced.
Old Mar 8, 2003 | 07:44 PM
Bill Vett's Avatar
Bill Vett
Default Re: Shake at 80 mph...... (Norris)
could be a tire out of round. :confused:
Old Mar 8, 2003 | 10:02 PM
chocoholic's Avatar
chocoholic
Your wheels most likely need balancing.
Old Mar 8, 2003 | 10:18 PM
clancy's Avatar
clancy
Default Re: Shake at 80 mph...... (chocoholic)
:iagree: Having been in the tire & auto service for forty years, your best bet is a balance problem, most likely, definitly the place to start. Hope this helps. :cheers:
TorchRedRaider's Avatar
TorchRedRaider
:iagree:
had the same prob at +80 and higher
when I got newer tires put on and balanced it has 99.9% gone away
of course now i'm a little hypersensitive to any shake or bumb now
Old Mar 8, 2003 | 10:29 PM
Thunder7's Avatar
Thunder7
Definately sounds like a tire issue. Either balance is slightly off on one of the front tires, or one of the tires is starting to have an issue/bulge somewhere. Have your tire guy/dealer check it out.
Old Mar 9, 2003 | 12:55 PM
Dave00C5's Avatar
Dave00C5
Default Re: Shake at 80 mph...... (Thunder7)
:iagree: Time for a tire balance. :thumbs:
To Shake at 80 mph......
