Tire sensor fault..help
Old Mar 9, 2003 | 03:08 PM
awaves's Avatar
awaves
Default Tire sensor fault..help
My front tire pressure readings are not showing and I have a message that says check tire monitoring system, Is this something maybe i can clear up or do I have to take it to the dealer? thanks in advance.
Old Mar 9, 2003 | 03:25 PM
footba4672's Avatar
footba4672
Default Re: Tire sensor fault..help (awaves)
have you done anything to cause the sensors not to work.....the sensors need to relearn the system
look in the search window for the procedure :steering:
Old Mar 9, 2003 | 08:08 PM
Racer1x's Avatar
Racer1x
Try this first
https://www.corvetteforum.com/techti...D=77&TopicID=1
If the horn does'nt honk at any one wheel,the sensor at that wheel is bad.The sensors are supposed to last about 5 years or so depending on useage.
Old Mar 10, 2003 | 12:31 AM
rhoeven's Avatar
rhoeven
As others said, do the relearn procedure first, but most likely, the tire pressure sensor is broken.
Same happened to me. Called Ken Fichtner with the year of my car and a few days later I received a new one.
Roger
To Tire sensor fault..help
