PCV Mod warning
Old Mar 11, 2003 | 02:21 PM
turboo2u's Avatar
turboo2u
Default PCV Mod warning
Went to Wal-Mart and found the HP 5138 filter for the PCV mod but the filter has a warning against using any synthetic oil or the glass might explode. Can this warning be safely ignored or have I missed something. Thanx. :confused:
Old Mar 11, 2003 | 02:46 PM
RskyBns's Avatar
RskyBns
Default Re: PCV Mod warning (turboo2u)
:confused: :lurk: I have this mod in my trunk all together and ready to be put on. :skep:
Old Mar 11, 2003 | 04:45 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
________________________________________ ________________________
From my own experience.....I would ignor it. I haven't heard of any failures with this Mod. I know there are a lot of Forum members using it. I just came back from the Ocean (Jones Beach) (Robert Moses Causeway) Did three 100 MPH plus runs. "120-130-&-130" Had to check out those 4:10's
Old Mar 11, 2003 | 08:13 PM
7Bob3's Avatar
7Bob3
The filter is made to be under 120 psi positive pressure. I don't believe 20 in of vacuum would be a concern.
Old Mar 11, 2003 | 09:46 PM
steve keen's Avatar
steve keen
Default Re: PCV Mod warning (Bob Blackmon)
:iagree: PUT MINE ON TODAY,AND WITH SEVERAL HARD CHARGES IT"S ALREADY CAUGHT OIL,BETTER IN THE TRAP THAN IN THE MOTOR! :seeya STEVE
Old Mar 12, 2003 | 05:07 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: PCV Mod warning (steve keen)
I have been running a Pep Boys filter(same thing) for about 6 months now with no problems whatsoever. Works like a charm.
Old Mar 12, 2003 | 05:10 AM
User 81424's Avatar
User 81424
Exactly!
Old Mar 12, 2003 | 05:18 AM
User 81424's Avatar
User 81424
See my answer this thread http://forums.corvetteforum.com/zerothread?id=511513
Old Mar 12, 2003 | 09:19 AM
wwashing's Avatar
wwashing
The nature of the warning seems to imply some sort of weakening of the glass because of some chemical (not pressure) reaction caused by synthetic oil. This most likely would occur over time. :cheers:
Old Mar 12, 2003 | 09:31 AM
User 81424's Avatar
User 81424
Default Re: PCV Mod warning (wwashing)
Right, but it's still 120 psi vs. a vacuum.
To PCV Mod warning
